RollingRocker
Standard Bore
- Joined
- May 24, 2012
- Messages
- 9
I have a 2012 R3R. I installed a Bikemaster Lithium battery which has a built-in voltage meter.
I am trying to ascertain the "acceptable" amount of battery drain if the bike is sitting in my garage (undriven).
For example, with the bike completely off and kill switch "on", should the battery be draining from 13.40 to 13.38 overnight? Is this just a normal discharge rate?
Do I always have to keep the trickle charger on to avoid the battery going dead?
What is an acceptable 24 hour drain rate if the bike is off?
Thanks-
Thanks-
