yep 10" width with a 280 tyre
I am on a new laptop but if i can find some pics of my last 3 bikes that i built i will upload them then you can see what i do with my bikes.....i like to be different 8)
Well,the 10" wide rim is the ideal size for a 280 tyre but it also works good on a 9.5" rim.
If need be i can get a stock wheel modified to take a 280x18 Metzler.
Maybe just a case of notching and strengthening the stock arm :?
If any one can , Chanders can . it will be a stunning incarnation of a Rocket . Look forward to seeing it :twisted: Full custom methinks if past records are anything to go by :lol:
Yep. I probably have only 1/4" between the tire and the shaft.
I think you would need a SPACER on the LH side at least, and possibly a notched or widened swing arm. It would be very cool. It would also get expensive fast. But anything can be done.
That would be some job making stock wheel 2" wider & 2"bigger diameter
That will need S/arm scolloped out, just about enough room, I was looking at doing that sometime ago,(thats why I have a couple of spare S/arms) but decided against it,I now have C/F 8.5"x 18 with 250 Cobra that is max tyre width recommended for 8.5"rim, & C/F 8.5"x 18 240 Cobra to go on front.
