Ok here is how the install went for those who may or might consider this horn. It is the rivco multi fit air horn. I removed the seat, headlight, and left side cover. I installed the compressor under the right side cover, after disconnecting the original horn I ran the stock wires to the headlight and installed the relay for the new horn, I removed the bolts for the left side neck cover and ran two wires through the cover, inside the bear claw and to the battery and side cover then reconected the headlight once all wires were connected to the relay. I ran the compressor hose behind the bear claw to the compressor and horn. I mounted the horn on the left side engine guard since I am short I was able to mount it directly in front of the peg. connect the power and ground and its done. took about an hour in the dark to install
