I am not sure what you are asking but I measured my 2015 Roadster and the gap between the plastic and 1st ridge is 5mm.
Yours looks fine from the photo. As long as the rear wheel axle spacer on the other side is on correctly (grooves inward towards rim) and nothing is binding it should be OK.
I didn't know how mm were effectively, for I never done with meter.
So I thought were less on my 2010 R, precisely 3mm rougly.
I hope it's so you think. I believe it's correctly inside wheel, I will check however.
