tachs....again....
ok....so the first tach was inop....2nd tach came in and works as advertised....have finished the drawings and I am having a new housing machined out of a block of 4x4x4 inch billet aluminum, with a screw-on bezel and custom handlebar-clamp back piece; the stock housing is a cheap and lightweight tin with a twist-lock plastic bezel and couldn't find a decent-looking way to adapt the included bracket to the handlebars......
...will have to cut the wires, especially the shift indicator lamp, in order to fit 'em thru the smaller hole in the rear of the housing, and 'boot' em with a rubber grommet; then, solder-splice the wires back together and wire it in....
...if the machining is not too expensive, I may make a few extra, if others are interested....will supply pix when the unit gets back from the machine shop....
