pod -v- k&n filters
slaphead
.060 Over
Sunny England
Tuneboy has a tune which includes the 3x pod filters, now is there a differance in fueling map using 3xk&n's instead..I seem to remember a post on here (carn't find it now :mad:) that its 5% but dont know which way!....
Thanks..
Thanks..
Slapper, isn't that the same thing? 3xpods or 3xK&Ns ???
Gday mate, technically and mechanically I am a qualified moron so take this post as you will, however, through experience I can say that when I originally removed the plenum and stock filter I used 3 pod Uni Filters. After reading about somebody's bad experience with the foam filters igniting and causing an engine fire I decided to replace then with K&N's.
With no other change I started experiencing all soughs of problems and then discovered that the air fuel mixture was out due to increased airflow from K&N's. Had a custom map by the genius at Peter stevens retune to suit the K&N's and of course he ****ed it up because they specialise in that at my dealership. The dropped 11 hp but when I sent it interstate to Lushie I ended up gaining 7hp with a tweak of my original Lushie tune.
Don't ask me why, how or any technical stuff but shows 18hp difference between technicians....moreso 7hp between uni filter and K&N on my bike.
