percentage increase
charlie farley
.060 Over
hi all ,
cant find the answer with a search so can anybody help Q. how do I apply a % increase/decrease to multiple cells in the fuel tables without having to do each individual cell at a time ? someone did explain but for the life of me I cant find it.
thanks Charlie.
I can only describe TuneECU. I believe Tuneboy is similar but I can't be sure. (edit: this is in the TuneECU forum so disregard the previous sentence)
In the table on TuneECU, click the first cell that you want to adjust. Hold Shift-key can click the last cell you want to adjust. All the cells in between should be highlighted. Then you can use your up and down arrow keys to make the adjustments. Click somewhere outside the cell range to finish.
You can also hold the ctrl key and click just the cells that you want to change. Shift-click will create a range of cells. Ctrl-click allows you to add individual cells to the selection.
Mouse wheel also raises/lowers it, 3% per wheel notch for me, not sure if all mice and PCs do 3% at a time.
I think the default mouse wheel is set for three text lines per click.
This can be adjusted in Control Panel under Mouse.
