For Sale SOLD - New Rocket III Head Gasket and Cam Cover Sealing Gasket
Jay
E pluribus unum
California, USA
2023 Rocket 3 GT (Ego), 2021 Zero SR/S (Earth)
I have a new Head Gasket (part number T1151150) and valve cover seal (part number T1260079) I had bought as left over parts from Gasket Kit T3990089. I thought I would get into some top end work to chase performance that would require these parts, but shifting focus. Figured someone on the forum can use these. I will be listing another complete kit seperately.
$110 for both shipped in the continental USA.
Yep engine numbers "> Eng No 254213" according to the parts listings but this "> Eng No" for most parts listings often actually means the last 6 digits of your VIN too.
Some later Classics had some early silver painted engines re-used/used up after the release of the later black painted engine series on Standards.
So it is worth checking for some parts variations.
The variations and later part numbers may also at times be improvements and fit the earlier series bikes and engines but the part listings simply confirm the part fitted at the time of release of that model.
There are experts on head gaskets in the Turbo and supercharging Rocket owners where it matters most.
Bingo
R-III-R Turbo
Rocket III Head gasket comparison 6 T1150189 vs T1151150
The early Silver engines also had a different sump and raised ridge gasket seal area later deleted but possibly better than the later sump and easier to get a good seal.
@Ishrub , thanks for clarifying. I was going off part numbers and knew this would fit my R3T. So this gasket will fit most engines, but still needs to be confirmed if you ride an earlier model.
Head gasket, Whether its an 06 whatever or a 2017 whatever you can only get the gasket you are selling, it will fit all models all years, only one available to order.
