Mitchcpc
- Joined
- Jul 1, 2007
- Messages
- 260
First of all let me say that the below will in no way lesson my love for my Rocket. I have had more fun on this bike in the last year than all the bikes I have owned in the last 30 years put together. I just wanted to share this with you all, the good and the bad. I really believe that with the exception of a few poorly designed or wrongfully installed parts, the rocket engine will far outlast any other current production engine.
So I go to Sturgis and back from Bremerton Washington and put about 3,500 miles on my bike. 07 standard rocket. VIN 316556. No problems, no idle issues, nothing. Except. On the way back, while in West Yellowstone, I start my bike up in the morning, it was pretty cold in the mornings there, about 38 degrees, and as it revs up to about 1,500 RPM, which it always does then settles right down at 800, I hear a tapping noise from the top of the engine. Some would describe it as a rattle. It reminded me of an old Datsun pick up I used to have with solid lifters that would "Float" and rattle when revved up. Anyway, it would only rattle at 1,500 rpm, not above or below, and as soon as it warmed up it went completely away.
From that point on when started cold it did the same thing, and went away a couple of minutes after the engine started.
So I figure it is probably just valve adjustment. I had calculated that as soon as I got home I would have 10K on the bike and need to get it in for my 10K service.
I planned to take it to I-90 Motorsports in Issaquah where I bought the bike, but after checking prices between them and the Lynnwood Cycle Barn that I had heard great things about from Gasket, I found that the labor at I-90 was $600 and at Lynnwood it was $445. So I decided to give Lynnwood Cycle Barn a shot.
Lynnwood Cycle Barn needs two days for this service. I found that driving my bike over on the Kingston/Edmonds ferry and then taking a cab back to the ferry was cheaper than trailering or having somebody ferry over to bring me back. A taxi from the Cycle Barn to the Edmonds ferry dock is $17.00. When I picked it up I just did the reverse. Walked on at Kingston and then taxi to the Cycle Barn. Alex at Cycle Barn set me up with the Taxi service.
So, I dropped my bike off on last Saturday and made several notes for the mechanic to look at.
Engine "rattle" at 1,500 RPM cold.
Front brakes squeak since new.
Front end wobbles at 45 MPH if I take my hands off the bars.
I had planned to just leave it there and pick it up the following Saturday. Bruce called Thursday and said my bike would be ready for pick up on Saturday, however...the rattle noise could not be resolved by the valve adjustments and my engine would need a tear down to investigate and repair, but that I could bring it back in the winter, it was OK to ride until then.
When I picked the bike up I asked for a copy of the mechanics handwritten notes.
The mechanics notes are "Unit does have a rattle in the motor that goes away when hot. Adjusted cam chain tension, top end noise is better than it was. Recommend riding bike and investigate further during winter when not riding, bike will be down for a while when motor comes apart"
I also asked for the before and after valve readings, all of which were in spec.
I asked Bruce to put in writing that this engine noise would be resolved under warranty and that I should continue to ride it at their direction, which he did. I feel that I can trust these guys. He admitted that other Rockets have had this same issue. I also printed out several posts from this forum about the "Upgrade" kit and gave them to Bruce. He had not heard personally about the "Upgrade" kit, but said he would look into it before I brought my bike back. I explained that although this was an inconvenience, I didn't mind so much as long as I didn't have to do this more than once. If they are taking my engine apart, I want all known or suspected weak parts replaced. He assured me that would happen.
And don't forget to ask for the extra two quarts of oil they charge you for but don't use because they only see the 15-50 in gallons. When I asked it was no problem, they brought it right out but sounded like most Rocket owners miss this part.
I also needed a new front tire, and they did resolve the squeaky front brakes. In fact, the brakes are a lot stiffer than when I took it in, they were getting kinda mushy. They gave me free install on the front tire due to the fact I was getting the 10K service. New spark plugs were also a part of the 10K service. All in all parts were $360 including the new front tire and labor was $445. All plus tax of course.
Lynnwood Cycle Barn has my vote for customer service. I felt like a valued customer.
I'll ride it a couple of months then take it back to get the rattle resolved. I'll let you all know how it turns out.
Right now I have to go install my cat bypass so Wing and A Prayer doesn't laugh at my cat box when we go on the Oyster run.
