Unfortunately no answer to this specific question for me, (in case anyone else runs into this issue in the future) but I was able to program the map successfully by hooking up a separate battery and tender, so I ultimately accomplished what I needed to.
I am 100% positive I pulled the #2 fuse for lighting and still saw lights (maybe it was just the DRL though?) The only plausible 20 amp fuse would be accessory. Are you saying the headlamps or DRL's are on the accessory fuse?
Same 2020 as mineβ¦the lighting fuse in that year does not supply power to the headlights. This was changed in following years. Only way is to manually disconnect them or (as I did) hook the battery up to a good booster.
