first upgrade for the rocket
first upgrade to the rocket
  • intake
    Votes: 18 18.8%
  • exhaust
    Votes: 64 66.7%
  • tune boy
    Votes: 19 19.8%
  • power commander
    Votes: 6 6.3%
  • cruz control
    Votes: 11 11.5%
  • GI pro
    Votes: 18 18.8%
  • Total voters
    96
triumphdude76
.040 Over
Euclid, Ohio
2008 Rocket 3 touring
This is going to be a poll for new rocket captains to use. As suggestions about upgrading there rocket.
you can vote for more then one.
I just purchased the GiPro as my first mod. Havent installed it yet but from what others are saying its quite an improvement for the money. Exhaust is tricky. Some people have put the T.O.R.S. on and not liked them....others do its a matter of taste. But what ever you chose, you found the right place to get info!
mutt
Had tors for 18 months since bike was new..now added Gipro...fantastic+!!!!would put gipro on first now as it is best bang for the buck and gives gear indicator as a bonus!
performance
ok what does this gizmo do beside showing which gear you are in.. obviously I am a newbie and need help!
performance
and since we are on the subject till now I understood tune was something you sang while in the shower but what is it really to EFI bike
I wonder if I should have stayed with carbs!! any body help!
Gipro-atre
HealTech Electronics Ltd. - Makers of the SpeedoHealer, GIpro and X-TRE - do a little research on their site for the Gipro-atre model for our Rockets..the R3owners site has a lot of installation helps/hints as they struggled thru the process..mine took 60 minutes as I read all the prior posts and benefitted from their experience.Do a search here and everything will be explained..Bob GIpro - Gear Indicator with Advanced TRE for Suzuki and Kawasaki motorcycles this might be better to go direct
Short response,
It UNrestricts the first 3 gears.
(meaning it'll run like a scalded ape)
and the blue or red gear indicator is nice too,
no more searching for 6th..
I couldn't give a truthful answer on the poll,
so I didn't vote.
My first mods were either
1) stebil horn
or
2) flipmeisters clamps
can't remember which was the actual first install.
As I understand a tune allows an EFI to be reprogrammed and have timing adjusted and fuel remapped [like rejeting carbs]. The Tuneboy has the added benefits of correcting the factory speedometer error, removing the factory timing retard in 1,2,3, gears, allows the secondary butterflies to open fully, and removes the factory top speed limiter. As opposed to a Power Commander witch will only adjust air fuel ratios to help compensate for intake / exhaust changes If I am mistaken I'm sure someone will correct me soon.
