albertaduke
former airline pilot without the big bucks
I generally hates electrics and sure enough I get this frustrating problem of an electric nature
explanation I decided to change the back turn indicators I reconnected the wires properly I also changed the rear light as well,I tested before buttoning everything and all lights worked as they are supposed to ...for 5 minutes then the left rear blinker stopped blinking actually it went dead no power then the right went dead and the flasher relay started making a whirring noise I figured the relay is shot bought another relay from triumph incidentally priced at $85 (highway robbery when an automotive relay is only $10 )I also bought the $10 relay back to the problem I hookup the new relay turn the ignition and... no power to the turn signal no flashing neither left nor right ..but the main rear light start FLASHING with either left or right selection and a faint light in the front turn signal as well as the yellow parking lights inside the head lights I look up the diagrams and I cannot find a common cause nor why the main rear light flashes when turn signal are selected any ideas from the electric brains out there!!
I should mention these new blinkers I installed are regular bulbs not LEDs
