Captain Bob
I put new rubber on my 08 R3T and when I took the back wheel off, I noticed the drive gear was lubed with wheel bearing grease. I found out that my dealer did this when replacing the tires due to a recall (prior to the bike being sold). I then removed the final drive unit and found the splines on the drive shaft were dryer then a bone. The splines were never greased at all.
I cleaned off the wheel bearing grease and lubed both the final drive and drive shaft splines with molybdnem(sp?) grease. Hard to believe Triumph does not lube those parts. Even the service manual says to lube them. Anyway, thought I would let you guys know that if you haven't already lubed those parts on your bikes, they are probably bone dry.
