...as the Captain from North of Detroit found out. The dealer set the freeplay too tight and he cooked the lifter shaft. The dealer replaced it but it didn't have to happen at all.
It's not the best designed clutch actuation out there but as long as the fitted components have freeplay (as in relaxed position) all is well. It's when there isn't any freeplay, it gets ugly.
Again, because of the design and because it's a relatively heavy clutch (spring wise) to transmit the torque, it's really not advisable to have the clutch disengaged (with the bike in gear) and rev the engine. If you want to do that, for whatever reason, the bike should be in neutral and the clutch lever released, in other words...hand off the clutch lever.
If you hold the clutch disengaged in gear and race the engine, it puts a tremendous strain on the lifter shaft and lifter piece not to mention the clutch basket...for no reason.
I know I said before that I put my bike in neutral at a traffic light and put it back in gear when the light changes and someone said that MSF frowns on that. Well, I grew up on 60's Brit bikes and that was SOP or the clutch ball welded itself to the release rod and you didn't go anywhere and the actuation mechanism on the R3 is similar. Not the same, but similar in action plus the clutch is 10 times heavier. My thought is 'better safe than poor'.
I was fiddling with mine again on Saturday. You can feel the difference between freeplay and all is tight but not disengaged in the seat of your pants, so long as you are attentive to what it feels like. There is a definite difference being loose and being tight and it's transmitted to your butt.
