To get rid of the decel popping, we fatten up the L tables which are used at low throttle positions (TP). In this range of the L tables, the A/F tables go over 14.57 and the ECU goes into closed loop and uses the O2 sensor to make it run smoother at low TP. However, when it's in closed loop, the ECU adapts and adjusts the fuel to give a leaner A/F regardless of the L table changes. So to keep this from happening, we keep it from going into closed loop by unchecking the O2 sensor box in Tuneboy or installing a PCIII O2 sensor bypass.
I've had the PCIII O2 bypass in and out many times and my conclusion is that the bike runs more smoothly at low TP in closed loop with the O2 sensor connected to the ECU. However, you get more decel popping, which I prefer over a tetchy throttle.
Any thoughts on this?
