Aftermarket Fuel Line Connection Replacement?
There you go no need to replace the entire fuel line I went through this recently when I pulled my tank I broke the fuel fitting. Ordered this off Amazon for cheap. O’reilly Autoparts carries it as well but they’re double the price of Amazon. Works perfect and have a spare for if/when it happens again
After diving into the rabbit hole I call the interwebs,I found Ac Performance has what is saying it fits I ordered 2 for only $13.00 and some change a 3/8 3/8 90° quick connect that is E85 ready not like the Dorman that isn't order through Amazon get it Friday and I'll let you know. One can go to performance shop and ask for a quick connect 3/8 female 90° to 3/8 male fitting to fuel hose and in stainless or aluminum,nylon plastic
Looking for the same thing can't find the female position, from the fuel rail only from the tank . You can buy the stock one but they want to sell you the whole hose which is part number. t1240349
Quick update. Over 300 miles later and ZERO issues. I don't even think about the repair anymore and this thread reminded me of it so I thought I would share.
It's not E85 compatible. The ethanol will eat through those o-rings. The AC Performance is E85 ready a 3/8x 3/8 90°
I'll let you know more Friday when I get it on. I guess one could change out the O-rings on the Dorman.
Awesome glad you found a good option. If I remember correctly the dorman fittings I posted were $15 on Amazon. O’reilly wanted $30 lol. They fit perfectly and haven’t leaked or anything so far. Plus so much easier to disconnect than the stock locking piece
can you share the link? I would like to order spares
Go to Amazon and type Ac Performance quick connect,I got the 3/8x3/8 90°
But guess I could have gone with the 5/16 or maybe the 1/4"male end
If you go to Amazon and input your make, model, and year to search for a fuel quick connect, it will appear. However, make sure the one you select is E85 compatible, as there are some that are not. Choose one with green release buttons.sorry just getting deep into the rabbit hole.
