barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Nope. You are wrong.Hype, this "motorcycle oil" stuff is hype. Our bikes have a CAR ENGINE stuffed onto a bicycle frame. Call it what you want to but it's still a car engine!
It is a UNIT construction engine with shared engine, transmission and clutch: dry sump oiling system.
I have not seen any car with shared transmission and engine lubrication.
Have not seen any car with a dry sump.
Automatic transmission clutches are lubricated but ONLY with transmission grade lubricants - manual box clutches are dry. Many manual gearboxes also specify ATF as lubricant.
The issue with non transmission/clutch rated oil in unit engines is NOT a new one. Ditto additives.
I can recall the general upset back in the 80's with stuff like Slik50.
