Tuneboy or Power Commander
1. Any map there is for PCIII you can import to tuneboy, so if you are planning on getting a PCIII and not dyno tuning, it is a waste.
2. http://www.tuneboy.com.au/Compare/Compare.html
3. Tuneboy takes a while to dyno tune and most places won't touch it. So if you want a custom dyno tune, use a PCIII, get the tune, then import the map into Tuneboy and remove the PCIII.
Also, you can use TuneBoy for doing your own diagnostics... ie. check DTCs (engine lights), reset TPS, etc..
All the above is true unless you experience problems with the program. Still trying to correct problems with Tuneboy , Guess I am a 1% . Does that make me a bad a$$.?
