Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,979
- Location
- Ride
Found the info now to find one! @Brennus
www.corbin.com
Rider Seating: 15" wide x 15.5" long
Passenger: 13" wide x 14" long
Approx. seat height: 27"
Brackets are shown yellow for illustration purposes only. Actual brackets come prepainted black.
Corbin Motorcycle Seats & Accessories | Triumph Rocket III | 800-538-7035
Installation: Dual Touring Saddle installs easily with brackets included. Installation is slightly different than your stock seat to provide the strength needed to support the integrated backrest system. Notice also we do not use a snorkel over the airbox and instead let the bike pull air from the entire under seat area (this actually frees up airflow). Since the Corbin basepan forms over the edges of the frame, you needn't worry about water intrusion either.
Simply install the Corbin bracket onto your fender with the included bolts. This provides the mounting points needed to mount the Dual Touring saddle. We recommend the use of Loctite or other threadlock compound and torque these bolts to 8 ft lbs. If using a heated model, you will also need to connect the wiring pigtail to your fusebox.
Now lower the seat into position with the tongue in the front and the side mounts lining up with the bracket you installed earlier. Secure with the included chrome button head bolts using a little Loctite and torque them to 6 ft lbs. You're ready to roll. Complete instructions included.
We recommend removing the seat from the bike when washing. In the case of the Rocket III, remember to cover your airbox when doing this to stop water from getting into the airbox!
Corbin Motorcycle Seats, Saddles, and Accessories Online
