For Sale Used IKON twin shocks for sale on USA eBay going cheap.
Ishrub
2x2010 ABS Roadsters, Sprint ST 1050 ABS, 3x250s
If someone wants some IKON twin shocks (made in Australia) for sale on USA eBay ... there is a used set going very, very cheap on USA eBay as the sellers do not realise they are not stock and actually IKONs. See eBay link below.
Just US$150 (+$15 postage) these are Ikon Rocket III shock absorbers - different SPRINGS AND REBUILDS ARE AVAIALBLE IN USA AND WORKDWIDE.
If std height and weight for Rocket Roadster they will be 7610-1650SP14.
They are still Au$770 (US$550) here in Oz retail.
Not sure which model for sure but likely the only std listing for the Roadster, 7610-1650SP14, but they should have the spring code on them.
If you ask them nicely, they may tell you the shaft length model and code of the springs (under the top black plastic damper adjuster from memory).
These are a good solid upgrade to stock and made to the old Koni Dutch company's designs and initially the Aussie company Ikon bought all of Koni dies and equipment when they ceased motorcycle suspension manufacture hence the name and familiar old models but they also do modern single shocks etc now too. Rebuildable too!
www.ikonsuspension.com.au
7610-1650 - IKONSUSPENSION
7610-1650 IKON Rear Shock Absorber and Spring assemblies. One Pair. Max Length 12.99" Min 10.79" Centre of Eye to Eye. These shocks fit: Triumph Rocket Roadster 10-12 Triumph Thunderbird 1600 09-12 Triumph Thunderbird Storm 1700 11-12 Triumph Thunderbird Commander 14-17 4 position...
4 position...
www.ebay.com
2011 TRIUMPH ROCKET III 3 ROADSTER ABS 2300 REAR SHOCKS | EBAY
This item is in GOOD condition. It includes everything pictured. It does not have any cracks. It is straight. The bearings are good. The bushings are good.
www.ebay.com
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/viewer.html?pdfurl=https%3A%2F%2Fwww.ikonsuspension.com%2Fwp-content%2Fuploads%2Ffull-ikon-shock-absorber-application-list.pdf&clen=647817&chunk=true
Triumph Rocket III (2300cc), including Classic, and Touring (original equip. seat height 730mm) 04-18
7610-1611
7610-1611SP8
7610-1611SP14
7610-1611SP16
7610-1611SP17
7614-1611
Triumph Rocket III (2300cc), including Classic, and Touring - LOWERING SHOCKS 04-18
7610-1612SP8 / SP14 / SP16 and 7614-1612 - Lowers the bike by approx 35mm.
7610-1612
7610-1612SP8
7610-1612SP14
7610-1612SP16
7610-1612SP17
7614-1612
Triumph Rocket III (2300cc), including Classic, and Touring (oe seat height 730mm) HEAVY DUTY 04-13
7610-1635
7610-1635SP8 Heavier duty springing for riders who like a firmer ride or are loading more than 90kg onto the bike more than 50% of the time at STANDARD height
Triumph Rocket Roadster (oe seat height 750mm) 10-19
7610-1650
76101650SP8
7610-1650SP14
7610-1650SP17
