Hi all... back in August 08 l asked if anyone could help with the noise my brakes are making...well after several suggestions from all over the world and no real answers....l came across the solution to the most irritating problem in the biking world.....
l bought some anti-squeal brake shims for a MK1 Ford Capri... cut them down and dropped them in between pistons and pads...now why did no-one suggest that to me earlier??.........it works 100%...no more noise... all the best to you all
Blacklll
Hi all .... please can someone help me here... l have a 2005 Rocket l bought new and have covered 19,000+ miles.... but a month ago the front brakes started sqealing... just as you come to halt... so about 10 or 15 mph down to complete standstill.. It still had the original pads (about two thirds worn) and discs in perfect condition. Now you may think me a little 'anal' here , but every two or three months l clean the calipers (on every bike l have owned for the last twenty years) with hot soapy water, around the pistons , and clean the pads , and wet n dry the pin smooth , then copperslip it and also the back of the pads... l just like to think l will be able to stop if l need to !!!!!!!!!!! but its making a real bad noise.. ln desperation l fitted new genuine Triumph pads , did my usual caliper clean-up , chamfered the leading edge of the pads and changed the brake fluid... and it makes more noise than ever... so l cleaned the pads and discs in brake cleaner.... it just made no difference... IT'S DRIVING ME MAD !!!!! any ideas , or known problems that l'm not aware of ???
thanku in anticipation
Blacklll
