**SOLD** 2005 Rocket III
Ha Ha.
Having had the expensive torsion damper bearing disintegration issue, the new cover is something I would look for in the 2004,5,6, and early '07's if I were looking to buy
one.
Warp may know if the black engine cover is also visually different or other ways to spot a replaced one.
It wouldn't be a show stopper and doesn't guarantee the entire Upgrade/Update Kit was installed - just something to factor in.
The odds are still low that you'll get a 'bad' one.
My estimate is that Triumph built 11,000 Rockets over that 3.2 year timeframe. It's still secret but at one point I heard 8th hand they said 4% could have had the output bearing(s) put on backwards. I think it is probably 11%.
That means that between 444 and 1,200 Rockets potentially had/have the issue. Most bearings installed backwards had signs (leaking oil around rubber seal) or failed between 10,000 and 25,000 miles so many bikes were covered under normal warranty or Triumph picked up the repair bill anyways.
Mine made it to 80,000 miles and I believe it was the first one where they refused to help defray any costs. I was so angry I've only bought one other Rocket since. LOL
Here the replaced cover is after 10 years - the cover is aging much better than the engine.
How much of the kit is here in this eBay listing?
Is this a part of that required kit?
TRIUMPH ROCKET 111 TORSIONAL DAMPNING BEARING DEALER KIT SILVER COVER T3990193
DEALER UPGRADE KIT FOR THE TORSIONAL DAMPER BEARING ROCKET 111. INCLUDES BEARINGS COVER GASKET AND SILVER COVER.
Note this is more than Fowlers price, but surely it is more than that one part?
5Kit, Torsional Damper CVR & BRGS
T3990192
Share this part
BACKORDERNO STOCK$93.35inc. VAT(£47.94)-QuantityMinusPlus
T3990193
Share this part
4+IN STOCK$93.35inc. VAT(£47.94)-QuantityMinusPlus
5Kit, Torsional Damper Bearings
T3990191
Share this part
Yes, those components are part of the greater update kit Black T1000008 or Silver T1000009 .
I found this part number list in the "kit of all kits" - for a black engine T1000008 from a 2008 post on the Rat forum.
Quantity Part Number Description Price
1 T1000011 ENGINE UPDATE KIT INSTRUCTIONS* $5.64
1 T1100045 KEY, CRANKSHAFT $13.68
1 T1140049 SPROCKET,CRANKSHAFT,19T* $71.56
1 T1140187 GASKET,TENSIONER* $3.50
1 T1140188 SPACER,SPRING,TENSIONE $16.42
1 T1142048 BLADE,CAM CHAIN TENSIONER,ALU* $113.93
1 T1142055 BLADE,CAM CHAIN,RUBBING,PA66* $51.36
1 T1160065 SLEEVE,THREADED,LONG* $53.15
1 T1160069 SLEEVE,THREADED,SHORT* $43.34
1 T1160096 SLEEVE,THREADED,M24 $43.34
1 T1160097 SLEEVE, THREADED, M24* $43.34
2 T1170092 NUT, CLUTCH,22MM* $23.38
5 T1171201 SPRING, CLUTCH* $61.65
1 T1179999 WASHER "C" CLUTCH $14.41
1 T1180051 WASHER,THRUST,41 OD X1.5* $5.76
1 T1180053 SHIM, STEEL, 45 X 32 X 1.0* $6.36
1 T1180064 GEAR,OUTPUT,2ND $157.65
1 T1180099 DOG RING, SPLINED $57.10
2 T1180267 BUSH, SHOULDERED, SPLINED* $72.90
2 T1180288 SPRING,BELLEVILLE,54.5X40.5X.6* $19.26
1 T1180289 SHIM, STEEL, 50X40X0.5* $6.36
1 T1190086 DETENT SPRING $6.51
1 T1190305 DETENT ARM ASSY* $26.54
1 T1197800 SHAFT, GEAR POSITION $45.48
1 T1230002 GASKET,SUMP* $23.72
1 T1241089 LEVEL SENDER, FUEL $136.83
1 T1241189 BRACKET, LEVEL SENDER* $20.25
1 T1260107 GASKET,CLUTCH COVER* $13.81
1 T1260119 GASKET,ALTERNATOR COVER* $15.27
1 T1260184 GASKET, OUTPUT SHAFT COVER* $17.38
1 T126030 SEAL,CAM COVER SCREW,TWIN LIP* $*4.53
1 T1260442 COVER,O/P SHAFT,PAINTED,BLACK $121.94
1 T1270850 BEARING,TORSIONAL DAMPER SB* $33.32
1 T1270870 CIRCLIP* $5.83
1 T1270886 WASHER,SPRING,DISC* $3.59
6 T1290180 SPARK PLUG, DPR7EA-9* $70.44
1 T1290567 HT LEAD SET $235.14
3 T2200326 EXHAUST PIPE SEALING RING* $29.79
1 T2208430 GASKET,EXHAUST,ID44.5,OD50.9* $21.80
1 T2208431 CLAMP,EXHAUST,ID53.3* $12.38
1 T2501444 HARNESS/INSTRUMENT REWORK KIT* $26.10
1 T2502531 DEALER REWORK KIT, LOCKSET* $62.05
1 T3050161 SCREW,CAP/HD,M8X1.25X20,RAW* $1.43
3 T3050302 CAPSCREW.SKT HD,M6X1X35,RAW* $6.09
3 T3051062 SCREW,CAP/HD,M6X1X12,ENC,RAW* $5.97
1 T3051063 SCREW,CAP/HD,M6X1X16,ENC,RAW* $0.91
3 T3051069 SCREW,CAP/HD,M6X1X10,ENC,RAW* $5.13
2 T3150132 BOLT,H/HD,SHLD,M8X1.25X18,RAW* $7.94
1 T3200220 BOLT,M8X1.25X14* $4.48
1 T3203090 BOLT,RHHF,M8X1.25X150,SILV,ENC* $13.63
1 T3203094 BOLT,RHHF,M8X1.25X165,SILV,ENC* $13.63
1 T3205653 BOLT,HHF,LGHTD,M8X1.25X30,SLV* $2.03
1 T3330186 SCREW,PAN/HD,TX,M6X1.0X25,BLK* $3.55
1 T3330831 BOLT,CAP/HD,M12X1.25X40,RAW* $8.90
3 T3332704 SCREW,TORX,C/S,M6X14,ENCAP,RAW* $20.88
1 T3350134 LOCKNUT, M10 X 1.25* $3.10
9 T3450200 PLUG, CHROME* $34.02
3 T3500003 CIRCLIP, 32MM SHAFT* $27.45
3 T3500202 CIRCLIP,EXT,29X1.5* $20.73
2 T3550128 WASHER,BANJO,M12 X 1.45 $6.30
2 T3550532 WASHER,CU,OD29.0,ID22.0,2.0* $3.12
1 T3550548 WASHER,CU,OD32.0,ID26.0,2.0* $1.56
1 T3551077 WASHER, M12* $9.98
1 T3600068 SEAL,OIL,40,62,6,CLOCKWISE* $11.57
1 T3600117 O RING, 17X3.0 $9.48
3 T3600134 O-RING,ID14.3SD2.4* $15.69
2 T3700015 CABLE TIE $2.78
1 T3801135 BEARING,BALL,45X75X16,SEALED* $52.19
1 T3880068 GAUGE,CAM CHAIN TENSIONER $113.93
Total Piece Parts $2,218.73
1 T1000008 KIT, UPDATE SERIES,BLK ENG $1,882.31 (in 2008!!)
It might be cheaper to just buy what you need...
