TRIIICK
- Joined
- May 29, 2008
- Messages
- 3,447
- Location
- Plymouth Massachusetts
- Ride
- 05 Rocket III 01 Roadking 08 Busa
This is an interesting concept, i wonder if it's really possible.
I built a net zero solar power house in 2011. The 2800square foot house only required 5kw of integrated solar roof panels. That is the size of a small portable generator. The power company FPL becomes the storage battery because the meter turns backwards when the homeowners are producing more power than they are using. We tried to design it net zero because the power companies in Florida only have to reimburse you what they deem the value of the current you are supplying them, which in the case of this home was three cents a kWh. In California there is a one to one law which means you receive what it would cost to buy. If Florida's legislature was not owned by big business every new home would be built like this and we would not need the two new nuclear plants that the legislature has allowed the power companies to start charging for.Half a kilowatt just to maintain +2 degrees C? I seriously doubt that. There are aquarium heaters that are 15 watts, for 10 gallons of water, and that keeps water 10 degrees over the surrounding temp. Plus, the heater wouldn't have to heat the entire hexagon - just the very top layer, and just enough that water evaporates.
