For Sale Sissy bar carrier
Wajhi
.060 Over
Dublin, California
Rocket 3 roadster 2015
Hi,
I order the low sissy bar kit, did not install the carrier.
let me know if anyone wants it, it’s chrome.
Hi,
Do you mean the #3 Luggage Rack A9733502 part only is for sale or is the whole Short sissy bar kit for sale now that you have not found a backpad?
SHORT SISSY BAR/LUGGAGE RACK A9738071
Requires a Sissy Bar Backrest Pad
(Does not include Sissy Bar Badge A9738002)
SISSY BAR BACKREST - CLASSIC A9708117 (later part number A9708177)
SISSY BAR BACKREST - STANDARD A9701144
SISSY BAR BACKREST - TOURING ( A9701145 Same shape as the Standard but has a rough textured side and rubbery smooth front vinyl that matches the Gel seat versions.)
Some pics
Did you find your back pad yet?
Another Triumph one T2300348 that will fit with an easy mod to the sissy bar is the flat squared off version used for many other models. They share the same bolt pattern, spacing and boss threads.
You would have to use a cutoff disc and remove the arch on your #2 sissy bar top to make it flat between uprights though.
These fit about 36 Triumph model versions over the years including America, Speedmaster, Bonnevilles in many different rack options so should be fairly easy to get still used or possibly even new old stock like the one I have.
Check ones from Thunderbirds (early 865/900 triple), Adventurer, America and Speedmaster carb and EFI models.
I have a New old stock one here. I have checked it has same 4 hole pattern and spacing.
Another in Japan.
As an FYI, the luggage rack listed for sale above (combined with mounting brackets 4 & 5 in the diagram and nuts & bolts) makes for an excellent top box mount that can be easily removed when not travelling.
PS My aren't those nice pipes!
