Here are those pics with some description added from what Richard told me...
All cool stuff. Real industrial look as there are a lot of exposed parts. For reliability in weather though I'd like the charger drive wheel and belt covered as well as some type of cover for that intake air filter.
From Richard's description of the install, I think it'd be doable in a few days for an amateur mechanic like me.
To give you an idea...
Radiator has to be removed to gain access to front of engine. Front engine cover needs removal to install stiffer clutch springs, though for those of us who've installed performance Barnett Clutch parts already then the new clutch springs are not needed.
Pic 1 shows the parts that will mesh with the lower cam gear and drive the supercharger. The lower cam gear is the thing under the black round cover in the front of the engine case.
Pic 3 shows a 10mm hole has to be drilled in an engine case fin for the lower supercharger mount. That fin is just cosmetic so you're not going to drill into the engine case or affect the engine in any way.
Pic 4 shows the bolt in the engine case that the upper supercharger mount uses. This is the same bolt that engine dresser bars use so if you still want to use them, you'll have to figure a way to extend the bolt farther so the dresser bar will fit on the bolt as well.
Pic 6 shows that the stock ignition coil bracket is cut in half so the two pieces can be mounted farther apart to let the super charger air feed pipe route in the center.
You can see from the pics that the stock airbox will be thrown out and the supercharger air feed pipe installed directly to the throttle bodies.
New fuel injectors, the combined supercharger oil tank/cooler are also installed. Also count in installing a Tuneboy or PCIII so the ECU is mapped correctly for this setup.
An intercooler is being developed that would mount behind the radiator on the right side. The left side already holds the supercharger oil tank/cooler.
