R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,548
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
Informative read; copy & pasted from TuneECU. But they lifted it from section 11.16 and 11.18 in the manual
The Rocket III is fitted with an electronic engine management system which encompasses control of
both ignition and fuel delivery. The electronic control module (ECM) draws information from Sensors
positioned around the engine, cooling and air intake Systems and precisely calculates ignition advance and fueling requirements for all engine speeds and loads.
In addition, the system has an on-board diagnostic function. This ensures that, should a malfunction
occur in the engine management system, the malfunction type, and engine data at the time the
malfunction occurred, are stored in the ECM memory.
This stored data can then be recovered using a special Service tool which is mandatory for all Triumph dealers.
In this way, precise diagnosis of a fault can be made and the fault quickly rectified.
System Actuators (varies by year and model)
n response to Signals received from the Sensors, the ECM controls and directs messages to a series of electronic and electro-mechanical actuators. The function and location of the actuators is given below.
Primary throttle stepper motor - situated at the front of the throttle bodies.
The primary throttle stepper actuates a cam lever which causes variations in the closed throttle position.
Although used primarily to ensure target idle speed is maintained, it also increases throttle opening when the engine is cold.
Second throttle stepper motor – situated between the throttle bodies for numbers one and two cylinders.
In response to direction from the ECM, the second throttle stepper motor movesthe second throttle spindle
to the position directed by the ECM. The second butterfly optimises engine torque by maintaining intake
air flow speed. It does not act as a choke for cold Start purposes.
Canister purge valve (California models only) - situated in the vapour return line between the
carbon canister and the throttle bodies.
The purge valve controls the return of vapour which has been stored in the carbon canister during the period when the engine is switched off. The valve is 'pulsed' by the ECM to give control over the rate at which the canister is purged.
lnjectors - located in the throttle body assembly.
The engine is fitted with three injectors. The Spray Pattern of the injectors is fixed but the length of time each injector can remain Open is variable according to operating conditions.
The duration of each injection is calculated by the ECM using data received from the various sensors in the system.
lgnition coils - mounted on a bracket, above the cam cover.
There are three coils fitted, one for each pair of spark plugs. The ECM controls the point at which the coils are switched on and off.
In calculating the switch-on time, the ECM allows sufficient time for the coils to charge to a level where a spark
can be produced. The coils are switched off at the point of ignition, the timing of which is optimised for good engine performance.
Fall detection switch - situated behind the left hand side cover.
The fall detection switch will detect if the motorcycle is on its side and will cut power to the ECM immediately.
This prevents the engine from running and the fuel pump from delivering fuel. In the event of a fall, the switch is reset by returning the bike to an upright position and switching the ignition off then back on again.
Main power relay - situated behind the left hand side cover.
When the ignition is switched on, the main power relay is powered up to provide a stable voltage supply for the ECM.
Fuel pump - located inside the fuel tank.
The electric pump delivers fuel into the fuel System, via a pressure regulator, at a constant 3 bar pressure.
The pump is run continuously when the engine is operating and is also run briefly when the ignition is first
switched on to ensure that 3 bar is available to the system as soon as the engine is cranked. Fuel pressure is controlled by a regulator also situated inside the fuel tank.
Cooling fan - located behind the radiator.
The ECM controls switching on and off of the cooling fan in response to a Signal received from the coolant temperature Sensor. When the coolant temperature rises to a level where the cooling effect of natural airflow is insufficient, the cooling fan is turned on by the ECM. When the coolant temperature falls sufficiently, the ECM turns the cooling fan off. The fan only becomes operational when the engine is running. It will not operate at any other time.
Note:
In this system, the Starter lockout system (clutch switch, neutral switch, sidestand
switch) all operate through the engine management ECM.
Supplement Rocket III Roadster
Brakes
Anti-lock Brake System <ABS>
System Description
The Rocket Ill Roadster is fitted with an electronic anti-lock brake system which is designed to prevent
the wheels from lockingor skidding by reducing braking effort to the front or rear brake caliper when
wheel lock is sensed.
The system consists of a hydraulic modulator and electronic control module <ECMl assembly mounted
to a bracket near the exhaust system link box, a front wheel speed sensor mounted to the front fork and
a rear wheel speed sensor mounted to the rear brake caliper carrier.
Both front and rear wheels have a pulser ring mounted on to the wheel hub.
The front and rear master cylinders are connected via lines to the modulator and from the modulator
the lines connect to the brake calipers.
The calipers and master cylinders are identical to the non-ABS equipped motorcycle.
The front and rear brake circuits operate as separate systems.The front and rear brakes are not connected
in any way inside the modulator.
The modulator ECM continuously measures the front and rear wheel speeds, and from these inputs the
ECM calculates the motorcycle speed, wheel deceleration/acceleration, front/rear wheel speed difference
and the wheel slip (skid) rate.
The later is calculated by comparing the wheel speeds with the vehicle speed, so that if one wheel speed
deviates significantly from the other two readings, this wheel is calculated to be slipping (skidding).
If the rider reduces braking effort, or traction increases (so that traction exceeds braking force, the wheel
will rotate once more) the wheel will no longer lock up.
The ABS system will detect this and stop controlling brake pressure, and return to its monitoring state.
The system has a self diagnostic function built-in which monitors the fail safe relay, solenoid valves,
motor relay, wheel speed sensors, power supply and ground, as well as internal ECM functions.
In the event of a malfunction being detected, the ECM will illuminate the ABS warning light, and store
a diagnostic trouble code in the system memory. This stored data can then be recovered using the
Triumph diagnostic tool which is mandatory for all Triumph dealers. In this way, precise diagnosis of
Under normal operation, the ABS warning light will stay illuminated after ignition on until the vehicle speed
exceeds 6 m/ph ( 10 km/h). The ABS performs a self check and if no faults are found the light is extinguished.
If a trouble code is stored the ABS warning light will stay illuminated and the ABS will not function, however
the brakes will operate normally.
If the ABS warning light does not extinguish, or illuminates whilst the motorcycle is being ridden, refer to
the ABS system diagnostics (see page 19-46).
Note:
Brakes
System Description
