Hi everyone I’ve got a 2010 roadster
Started having problems with the instrument panel flashing on and off and resetting and starting first thing in the morning. I first noticed the clocks resetting whilst parking the bike with the handlebars full turn.
Decided to investigate the issue and raised the tank to find a proper jumbled mess.... after a couple of wiggles the clocks come back to life and the bike started ok, - so I figured it was the connection block I wiggled that had the issue, after freeing everything I lost all clocks and no turning over...
I have lights, indicators and horns and I hear relays click when I turn the key, I have no clocks and do not hear the fuel pump. The bikes in neutral and the kill switch is fine - I suspected a corroded connector block, but have checked them all and they seem fine (all cleaned). I have 12v at the ignition connector block and have measured 12v at one of the soldered connections on the bottom of the ignition.... I’m now suspecting a broken wire somewhere in the loom, the ignition itself or a relay..... anyone got any experience of where to start
