For Sale for sale classic t bars
mickm7
.040 Over
gilgandra nsw Australia
2008 classic
for sale a set of tbars they were removed off a classic...they are not new and do have some marks, nothing major
i was goiing to install on my bike then worked out once installed you cant lift fuel tank..
height is 350mm width 820mm pullback app 200mm bars are 2inch diameter brand unknown...
have worked out if throttle and clutch cables are moved behind top tree they reach...also mounting bolt is larger than original so will require to be drilled..
does have a braided front brake line...
happy to freight at your expense,
open to reasonable offers..
How much do you want and do you have the bolts that they were fitted with on the R3Classic or know the size and thread and what needs to be drilled? Did you see them fitted and/or have you checked if the R3 Classic hand controls fitted the cutouts correctly?
It is possible they are Harley fitment with ½” UNC threads.
you make me an offer be realistic, I seen the remains of the bike, bars still had controls on them with internal wiring which was
a horrible job so removed, top tree needs to have holes drilled out to 1/2 inch or 13mm..i had them all but on my bike
until I found that I couldn't lift tank...yes the mount bolts are there..also mount plate for gauges..
