What is the diference between ECUs Classic and Touring ??
Why R3 Touring has a diferent map for Brazil and Classic dont?
Can I use the Touring map in my Classic?
Iam from Brazil.
The 'brains' are all the same. The thoughts are different.
The reason there are different 'tunes' with different parameters is to address different acessories. European (and I presume Brazil) tunes have a power limiting feature. The EU requires a horsepower limit that's less than the domestic bike makes.
You can use any tune in your bike so long as the tune you use is applicable for the equipment your bike has, for instance, if you have TOR's and a cat bypass, it will require a different tune than if you have the stock pipes and a filled cat box.
Interestingly, I found out this week that it's possible to load
any Triumph tune in the computer, that is, you can load a Speed Triple tune in the R3. If, that's a good idea, I'm not sure, but it can be done and has been.
There are differences between the new Touring model and the R3 Standard - Classic besides tunes. There are physical differences in the fuel injection units and I believe in the cams. The engines themselves are the same displacement and share the same physical characteristics and parts like the radiators and the oil tanks and other bits.
