dobeck
sixpack
New Brunswick Canada
do you think the dobeck will work with gripro atre and secondairies removed, ( 06 R3 stock pipes and filter w/ cat eliminator 20227 triumph tune )??? TIA
There isn't much you need to do with stock exhaust and intake. Those two are the limiting factors keeping the mixture from going too lean. Removing the secondaries will cause it to lean out a little, but it's the intake and exhaust that keeps the mix rich by limiting the movement of air.
I'll bet the dobeck would be perfect for your situation.
