Decel pop advice if you will.
RockyIII
Brazil
I thought I would just ask this and make some light conversation in the process.
With the triples tune I'm currently running by Wayne-tripp, I only get loud pops and bangs between about 3100/3200 to 4200rpm or thereabouts.
What would be the best option for curing this. Now I understand about adding fuel to the 0 column, but should I only add to that part of the rev range or the entire column and how much?
Is it only the 0 column I need to think about?
Just after some sensible recommendations that's all, cheers.
P.S I still haven't managed to cure the prolonged high idle on start up, and only on start up. It's only about 5-7 seconds but a little strange i think.
I run a triple filters setup with jardine exhaust and use the 20145 by wayne tripp and I have no popping at any RPM check this tune (20145) it is designed specifically for triple filters and jardines are you running Jardines??
Thanks for that, I have also tried that tune. I had some issues with tunes not being the 20050 variety. So what I do is copy all the tables from a non 20050 tune into a 20050 tune.
I know it sounds really odd, but it's worked for me. I might be an isolated case.
I'll have another look at that tune, cheers.
