R3 crazy chris
Don't know what this noise is but it sounds just like a fan belt sequel on a car when I accelerate. I have been searching for info on here but haven't found anything yet, any info would b great..... Thanks
We call it a "burnout" caused by the rear tyre trying to tear up the tar road!
The water pump may have been tweaked, if it has... be careful as it can cause the oil pump to stop.
A long large screwdriver works well too if the noise is audible while stopped. Place the handle against your ear and touch the end to different places on the engine. It's amazing how noisy the inside of an engine really is.Look for damage to the pump. You can use a piece of tube to use as a stethoscope and narrow down the location of the noise.
Try it after you piss her off. You will hear something then.I have tried out this procedure on the missus, never knew there was so much noise inside that motor
