BuffaloR3
.060 Over
I know the previous owner screwed with this at one point and might have messed it up (he swapped handle bars so he had to dis/reassemble the throttle) or I'm missing something. I'm installing the Rivco handle bar risers and re-routing the cables, one of the steps is to disassemble the throttle assembly, reroute the cable and put it back together - that is where I'm having the problem. I've put as much slack in the line that the adjuster allows and there is just not enough to get this back together, it came apart by one of the cables popping out of the guide unexpectedly (pretty much as soon as I took the clamp off) and the plastic "clip" was bent in a not so good way. Now trying to get them back onto the grip is impossible. I've figured out where to roll the throttle body at the intake to give me some slack to put in the one side of the cable, put in the other one and release, but then when I try and wrap it around the grip there is just not enough slack. Going the other direction of winding it around and then trying to stretch it into the "clip" is not even remotely possible, a good 1/2" short.
Is there slack to be had elsewhere in these lines (where they connect to the throttle body maybe) or am I missing some trick? I've done this on other bikes and remember there being plenty of slack to assemble and then just tightened the adjusters when done.
