JeffR3Colorado
I need a little advice. I have a 2007 R3 Tourer. I upgraded the starter/solenoid to a 1.8kw unit from a 2001 Toyota highlander (new). After shortening the push rod & bolting up the triumph gear box. It all bolted up clean. I bench tested the unit and it almost jumps off the table. Reconnect it to the bike and all I get is a single click. My ignition wire is only bringing down 11.6v to the solenoid. Bench test I was jumping straight from the battery with 12.5v. I check ground to engine and frame and i get
.2 olms, so i think it is grounded good. So is that lose of 1v causing the solenoid not to fully engage? Am I losing that volt to the lighting circut? Or something else? Where do I look next? Thanks in advance for any suggestions you may have.
