Red Vapor
.040 Over
I am wiring in the oxford heated grips into my stock harness. I already had them hooked up stock for oxford and they worked great they have a adjustable temp controler. I order from triumph the harness and sub harness with relay. Im not getting power to the oxford controller at all. The stock triumph switch is a high, low neutral setup, the oxford is a variable unit do you think the relay is messing it up where its not getting power. Any Ideas guys
