Misaligned Grille?
Went and checked mine as I had swapped out the upper shrouds for carbon and didn't touch the lower shroud. Turns out mine sits a little more proud on the left as well, and has a bit more "give" in it when you push it. I am guessing either the hose behind it is putting pressure on it, or I have a clip not seated properly. I doubt it is just a clip as pushing it into where it should sit doesn't latch anything. Barely noticeable, so not too concerned.
So I just got my Rocket 3, so I'm still discovering things..
One thing I noticed today, was the grille below the radiator is misaligned.
Is this the same on every bike Or is there a issue with mine?
I cant remember where but someone has put a fix for it, its quit a bit of work,
