Current tune
lea3792
Greeting , does any body know what the current tune for an 06 classic is. I took my honey to Atlantic Motorcycle in Pompano Beach Fl. for a check up and they advised I had the current tune (20215). Took my baby out for a spin and as I was about to make a right hand turn, she stalled. I recovered before making the turn and got her home without incident. Either I was very lucky or I am getting better at riding. Looking forward to your reply's!!!
Lea
Stalled due to simple operator error, or did it just die off idle at the junction? Is the bike stock/unmodded? the dealer can reset the stock idle( but their programme is limited) Tuneboy ( yes tuneboy again! :lol has the function of setting the idle across a whole range of engine temps.. something that fixed mine when it was fine cold/warm, but would'nt hold idle on a hot start.
Thanks for the quick reply. First I was (still having) problems with the first gear slippage and now my baby stalled at a very intersection. Operator error - I don't think so but I am not ruling anything out. My baby is stock for the most part. I installed GI pro the other day and it seems to be working well. I don't think the GI pro is the problem. I guess time will tell. Talk to you soon.
Lea
Blasted my good man, of what do you speak ? I know only of the box where you put in the desired idle speed. Is there another area ? Do tell !
Yup as IDK said its in the latest downloads, its found as a tab at the far right on the same line as the F, L & I tabs.
People say you need to delete the old 3.4 programme, but its not so. just download the tuneedit zip file into its own folder, extract all files, BUT don't move to desktop, just keep it bound in it's folder. Then when you use it, just open the tuneedit folder & click in the green grid inside. I can do that without interfeering with the old programme..BUT.. here's the but.. IF you alter any old programme( tune) in the NEW tune edit.... it won't load into the old 3.4 tuneedit again!:shock:
So make copies of the tunes first & keep them in a seperate tune folder.
