Tune Mods for R3T with Jardines
GPMAZ
Moderator
Staff member
Arizona
I'm considering swapping my D&Ds for a full Jardine system. I haven't found anyone who has installed the Jardines on an R3T. I currently have triple K&Ns with the 138HP tune for the R3T.
I'm pretty sure I will need to more fuel to support the added flow of the Jardines. Does anyone have any suggestions as to how much fuel I should add via the Fuel Trim tables to be safe until I can get it on a dyno?
Solid lines = power
Dashed lines = torque
Red - stock R3T with holes drilled in baffles (stock exhaust). TORS tune.
Orange - Above after tuning with TuneEdit.
Green - R3T with Jardines, secondary throttle plates removed, and triple K&N RU-2780 under bearclaw. TORS tune.
Blue - Above after Tuning with TuneEdit.
As you can see, the restriction is not in the Jardines and air filters. Not much of a difference in the post-tuned bikes at higher rpm, but there is a difference at low rpm and through the midrange.
Compared to the stock and TORS tunes for the R3T, there is a lot of work involved in fueling (F and L tables) for best output.
I hope this helps.
-Wayne at power-tripp.com
