New Mods
Discussion in 'Custom Mods' started by Manic_Mechanic, Mar 20, 2011.
  1. Manic_Mechanic
    Manic_Mechanic Supercharged
    Country:
    United States
    379
    Featured Threads:
    17
    Media:
    22
    96
    28
    Spring Grove, Pa.
    Rides:
    05 Rocket
    Haven't contributed anything lately so here we go.
    Read a thread here some time ago about the headlight/ignition switch issue so I ordered the kit from eastern beaver and while I was at it I got the harness for the horn since I had switched over to fiamm air horns over a year ago and toasted my horn button. Well the box of harness was sitting unopened for the last 3 months and I finally got around to the install last Monday. It went so well that after making sure the lights and horns worked (with a new beefier compressor)I figured I might as well take care of a few more back burner projects that I had been putting off. The bear claw was still laying on the floor so I removed the coolant expansion tank and moved it to where the air filter USED to be before the k&n's were added. Now I had room to experiment with re-locating the horn compressor under the bear claw. After an hour and a bracket that spanned the two bolt holes that were previously used by the expansion tank I had a suitable mock up. Tried it with the b/c and after a few minor adjustments I was happy. LOUD HORNS and BRIGHTER LIGHTS.
    The only thing left was a good cleaning and re-oiling of the k&n's. It is now officially spring.
    GrizzlyRider likes this.
  2. scot in exile
    scot in exile Living Legend
    Country:
    United States
    3,139
    Featured Threads:
    89
    1,504
    813
    Fort walton Beach FL, Glenrothes Fife
    Sounds like you had some fun:D enjoy the new mods until the next ones come along.;)
  3. pkn45
    pkn45 .020 Over
    12
    0
    1
    Great Bend, Kansas
    I did not know that you could buy a relay kit for the headlamps. After reading the wirering diagrams I made my own kit and omega had to cur one wire on the factory harness.
    And thanks for the idea of moving the coolant overflow tank to under the seat. Ill like not seeing that tank.
    I do have a question. I'm looking to flush the cooling system. I work at a Dodge dealership in western Kansas. And after having a team of parts Guy try and find blue coolant for an entire afternoon they had no success. I was told that I could convert from blue to red coolant. Is that true? Thanks for the help.
  4. scot in exile
    Country:
    United States
    3,139
    Featured Threads:
    89
    1,504
    813
    Going by the specs.
    An all season type of anti-freeze is installed in the cooling system when the bike leaves the factory, it is coloured blue, contains a 50% solution of ethylene glycol and has a freezing point of -35c.
    The coolant contains a corrosian inhibitor.
    Never use a methanol based anti-freeze as this does not contain the required corrosion inhibition properties.
    I do not know if each company has its own colour but any anti-freeze meeting the above specs should be fine be it purple,pink,green or tartan.
  5. pkn45
    pkn45 .020 Over
    12
    0
    1
    Great Bend, Kansas
    That will do. Thanks Scot in exile
  6. Manic_Mechanic
    Country:
    United States
    379
    Featured Threads:
    17
    Media:
    22
    96
    28
    Spring Grove, Pa.
    Rides:
    05 Rocket
    I just found a supplier for tartan.
  7. Manic_Mechanic
    Country:
    United States
    379
    Featured Threads:
    17
    Media:
    22
    96
    28
    Spring Grove, Pa.
    Rides:
    05 Rocket
    Forgot I was going to post pics.
  8. Manic_Mechanic
    Country:
    United States
    379
    Featured Threads:
    17
    Media:
    22
    96
    28
    Spring Grove, Pa.
    Rides:
    05 Rocket
    And then there is this one also.
  9. meanchuck
    meanchuck .060 Over
    Country:
    United States
    105
    Featured Threads:
    5
    Media:
    14
    44
    28
    PA
    So did the headlight relay kit make a big difference?
  10. Manic_Mechanic
    Country:
    United States
    379
    Featured Threads:
    17
    Media:
    22
    96
    28
    Spring Grove, Pa.
    Rides:
    05 Rocket
    I can see a difference but there is that warm fuzzy feeling of knowing I'm not going to burn up my ignition switch.
Share This Page
Loading...
Triumph Rocket III
