i have a rocket 3 tour with triumph off road pipes, k & n air filter. which of the tune boy tunes do you guys think i need or would work best for me.
If you haven't removed the snorkel under the seat, the tune is 20258. You should definitely get rid of the snorkel. Then the tune is 20256_1.
Squinting at the picture in your post, I see you have the Touring model, not to be confused with the Tourer model produced earlier. Too bad Triumph had to make it so confusing, but as you see, there is no such thing as a Tour.
Pig9R is right about the tune. That K&N adds very little in the way of performance. But, as Doug says, if you're going to keep it, remove the snorkel. Swapping to the triple K&Ns and the appropriate tune will yield a much bigger gain.
Additionally, I happen to have the triple K&N's in stock plus the AT sensor filter and the crankcase filter for the non-existent air box filter...when you put on the triple underseat filters you'll have more storage space....under the seat.
They are on my website...............:)
