aztom66
I have a 2010 Rocket 3 w/ 5k on it. I had the triumph slip on pipes installed along with the triumph map for the pipes. The sound is richer and there is a bit more rumble in the seat. The issue I'm having is when I fill the tank, The gauge will reset it self to about 165 miles to E, and then clime to around 207 til E, then at about 25 miles on the tank I can see the fuel gauge drop to the half mark. I know this is a false reading ...cause when I remove the filler cap I can still see the fuel level. I have also noticed my mileage has been reduced, before the slip on pipes I was averaging 36 to 42 MPG depending on how hard I pushed. Now I'm looking at 18 to 25 MPG. The slip on did not change the HP output, so would it have that effect on MPG?
