T Evans
Ok, I have decided to go with the triple filters but am thinking about getting the smaller ones that will fit under my Bear Claw. I have sense heard that there is a significant difference in HP between the small filters that will fit under the claw and the larger filters that wont fit under the claw.
The way I understand it is that the larger filters flow more air thus produce more HP? If this is the case, does anyone know how much difference there is or is it 5 hp or less. If you can see a gain of 10 hp difference by going with the larger filters, then a guy may have to look at going that route over the smaller ones.
When you load your different maps into your PCIII or your Tuneboy, does it ask which pod filters you are running, large or small?
Thanks guys
Big T
Thanks guys
Big T
