patrol21
.060 Over
- Joined
- May 15, 2013
- Messages
- 119
- Location
- Rochester NY
- Ride
- 2009 R3 RAMAIR Intake Full Jardine Exhaust Cor
Aloha....out riding yesterday...2009 Rocket3. Under 10K. Nasty noise and curbside. First thought I snapped the clutch cable...nada...clutch engager arm is flopping around....have found there is a weak design flaw with some pin ..lifter piece..and chatting with some folks and checking manual this looks like it is the issue as the head of the pin snaps.... Anyhow, on bike bandit it shows a motor number of 249178 and higher as there must have been a change over near then. Seems a low number for a 2009. I don't have the bike in front of me and want to order parts so wondering if anyone has some info on engine number and aprox year this change was made. Couple more questions
Parts to buy-Lifter piece.
Front gasket
New antifreeze as I have to remove the radiator.
Oil change....might as well s I will dumping the oil.
Thoughts on any other parts needed? I see a few small parts and a bearing also that I may just replace.
My question is as I have never torn into a Rockets clutch...I assume the head of the pin inserts into the front pressure plate. I need to dig this piece out so will the front plate need to be removed as I assume the pin inserts and is set on the back side of the plate or is it attached on the front facing portion? no schematic to look at in the manual.
Front gasket
