RIchareno
So this seems to be a common problem with these bikes. I've had my 2009 Classic for one week and the lights have never worked. I assumed it would be something simple so I didn't worry about it, but after ruling out the fuse, starter relay and bulbs I'm left with only the switch and the wiring harnesses under the tank. I will check those tomorrow. and put a volt meter on the bulb plug as well as check for continuity between the switch/bulb and the switch/fuse. Any words of advice? The running lights work but nothing to the bulbs. The highbeam indicator does not work either. I changed out the starter relay and fuse with new ones, nothing. Is there some common issue that pops up repeatedly that I don't know about?
Thanks, guys.
Thanks, guys.
