Nat67
Rockgoblin
Hey guys , my 2010 t has been running real sweet . After a lay up of a week I decided to take her out .
Start up and tick over fine but then when cracking the throttle , once warm ,engine seems to delay and then fire on 2 .if you partially shut the throttle then crack it again everything is fine until it returns to idle and then symptoms repeat ! Once rolling , all is good and runs fine til the occasional stop junction when the symptoms would return . Took it for a good 80 mile run to blow the cobwebs but the miss intermittently returned on commencing town work again ! As I said , all has been fine up to today !
Bike has ramair and tors . Was thinking maybe TPS but this was set getting on 1 month ago along with throttle body balance and new plugs . The problem only occurs in first gear or neutral ? Would appreciate your advice ! I don't have tune ecu but I do have pcv.
