A more efficient exhaust system will allow the air out of the cylinder faster, and also allow more to get out when it
blows. This will allow more space for air to get in when it
sucks. If you have more air getting in but only the same amount of fuel then it will be running lean, and therefore hotter when it
bangs. This will lose you power and could also burn valves and other bits in the engine. This is not good. Therefore you need to bike tuned differently to get the A/F mixture correct.
If the air can get into the cylinder more efficiently because of a better intake system then you will have the same issues.[/
**** is it getting hot in here? Or is it just me....
