A parameter of octane rating is resistance to ignition and the rate of combustion.
Higher octane; higher resistance to ignition and a more controlled combustion rate.
Higher octane is for compression ratios of 10:1 or higher and or hotter (temperature) engines to eliminate pre-detonation.
A quality 89 octane (US, RM/2) is perfect for the Rocket that still retains OEM compression ratio and timing advance.
I have a Rocket buddy with TORs and cat-bypass that I would hate to ride behind because of all the popping and farting on decel.
One day we are riding and pull in for gas.
I see him putting 93 octane in.........WTF!!!!
I tell him NO!!!...use the 89!!!!....this is why your Rocket sounds like the 4th of July on decel.
He is now convinced and only uses 89...most if not all of the decel popping is gone.
The 93 octane WILL NOT completely ignite in a stock Rocket engine with 8.9 CR and simply collects in exhaust.
During decel when your Rocket engine turns into a 2300cc air pump you get the ingredients for pop-boom-bang!!!
Un-burned fuel, fresh air and a hot exhaust providing a secondary ignition source.
This is all I would like to say.
Hope this helps someone, somewhere....somehow...
Gary
