zimtuff
Nitrous
It started off by changing the plugs. The old Iridiums had done 70000klms and were taking longer to warm up. I put in some NGK standard type plugs and it was much better on start up.
But I began to notice some drive train slop caused by a very small miss in the engine at a constant speed, mainly 100-200 rpms either side of 2000rpms. On acceleration it would go away but there was a very slight hesitation before it pulled strongly.
A few days ago I lifted the tank after syphoning the fuel out. I had a feel around the wiring making sure all the spark plug leads and coil wires were properly connected at each end.
While the tank was in the vertical position I started the engine and had it running. It seemed to be running no worse than before ,then it cut out. I thought maybe it had run out of fuel ,so I put the fuel back in.
I got it started but it runs like crap , maybe on 2 cyls or sometimes 1 cyl and the engine check light is on. Some irregular small black puffs of smoke
I had another go yesterday. Its difficult to start, you have to give it some throttle and hold the throttle at 1700 and them it begins to run a little better. It seems to be going through its normal cold start cycle of high idle then coming down to around its idle speed of 900. But it gets slower and slower.
I originally had a tune boy tune. But I have ordered a cable and will try and nut out the tuneecu when it gets here.
Ive tried disconnecting and reconnecting the battery
Any ideas out there?
