cootertwo
- Joined
- Mar 24, 2013
- Messages
- 2,043
- Location
- Labelle Florida USA
- Ride
- 2013, & 2 05's R3R, 2006, 2004 Harley's, 2004 Kaw
Hi all, well, I must be feeling better, as I went out today, and pulled the front cover off my 05 Rocket. Besides a juddering clutch, which I think is from me leaving out the judder spring on my Barnett install, I've had this weird shift thing going on, for quite a long while. Kinda hard to explain, so I tried to get a video of it. Video is with bike in neutral, if I lift on the shift lever, there's nothing there, no spring tension, kinda like it's not connected. If I gently push down, not enough to shift, there is spring tension, (detent spring). On my other 2 Rockets, I have slight spring tension both up and down, while in neutral. On this problem 05, I've never had it pop out of gear, but when up-shifting, sometimes it takes a double lift, to up-shift. I've learned while riding, when ready to up-shift, if I slightly lift, and if I feel nothing, to let off, and on second slight lift, it is solid, and will up-shift no problem. I've quit for the day, but tomorrow, will pull the clutch and basket. I'm suspecting the weird shaped spring, that I've heard of one end or the other breaking off.
Triumph SPRING,GEARCHANGE,RETURN Part # T1190011
My detent spring is on, and intact.
