Waterless Engine Coolant
I've read some good things about it, but I've been so happy with 'Ready to use' EngineIce I've no reason to switch. Be sure to share how it goes if go the Evan's route
-MIG
Sounds like a good way to avoid the corrosion inherent with iron and oxygen mixing. The engine components of most bikes has very little iron however (unless it's a Harley) so the only question is does it last any longer than standard coolant? The cost/benefit ratio might be higher for higher performance engines. Do post up your results.
they claim "it lasts for the life of the engine, so you never have to add or change coolant or flush your radiator, saving you time and money."
